Control Circuit Design Contact Inductive Break
Hi
I am looking for a good book which describes how to design control circuits.  For example I have a 125 VDC circuit with one contact in series with a solenoid valve. The solenoid valve is 35 watts which means in draws .28 amps in a 125 VDC circuit.  The inductive break of my contact is 1 amp @ 125 VDC so I think I am fine.  What else am I missing?  Do I have to include the resistance in the wire or any other factors? What if I have a resistive element in series with the solenoid?  Are there any equations which relate the resistive and inductive break ratings of the contact?
RE: Control Circuit Design Contact Inductive Break
No other resistance needed.  You might want to put a back biased diode across the solenoid as it will reduce arcing and increase the life of the relay contacts. Or not.
Keith Cress
