Which viscosity correlation for low presure system?
I need to calculate natural gas viscosity for these ranges:
SG 0.5 to 0.65
Temperature 2 to 30 degrees celsius
Pressure 30 to 650 psia
I was planning on using the Lee correlation but it is only valid for pressures greater than 100psia.
Are there any non-graphical correlations that would work well?
SG 0.5 to 0.65
RE: Which viscosity correlation for low presure system?
section 20, equations 23-20 to 23-26.
