Mixing of MIL-PRF-7808 with MIL-PRF-23699
I am not sure if this question is appropriate for this forum. I tried Engine & Turbine Engineering forum first, but think maybe there are experts in this forum who have experience with these two oils.
My question concerns the mixing of MIL-PRF-23699 and MIL-PRF-7808 in an aircraft turbine engine (JT3D-7).
On one side I have an engineer who states that we can unconditionally mix these oils in any quantity/ratio, with no documentation or limiting conditions.
Printed data I have found states that these oils can be mixed in emergency situations, but under the condition not to exceed more than 50% of the oil tank capacity and at the first opportunity the oil tank shall be drained and reserviced with the correct oil (42B2-1-1 dated July 2005).
P&W has a service bulletin advising I can change from 7808 to 23699, but have to drain and re-service with 23699 and stencil the tank with the new oil number and document this change. Nowhere does the SB state I can service without condition between 7808 and 23699.
Obviously, either oil can be used. What (if any) adverse effects, both long and short term, could there be with mixing of the two?
Does anyone have any thoughts or input?
RE: Mixing of MIL-PRF-7808 with MIL-PRF-23699
