Large diameter Stainless Steel Fasteners?
This could be asked in several different fora, but I'm going to give it a shot here first.
We own a number of bridges, including several trusses. Most of these trusses are made of built-up riveted steel members. The sections of the trusses are assembled with very large diameter pins, often located at both ends of a single member in each plane of the truss. This permits some relief of forces due to changes in temperature, but has other consequences.
Our consultant engineer was asked to specify stainless steel (ASTM A276, type 316) for these pins. The engineer called to ask me if such a thing was available. My involvement with stailness steel to this point has been limited to threaded fasteners up to about 1 inch diameter. Does anyone know where type 316 stainless steel is produced in pins five inches in diameter?
Our standard specifications for pins in this size range call for ASTM A668, Class D or Class F. Therefore, I believe we will be searching for somethig with comparable strength to these grades. Thanks for your help.
RE: Large diameter Stainless Steel Fasteners?
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Try contacting Outokumpu stainless. They have a sales office in the Chicago area. They have a bar facility here in the US. They might be able to get you either cold finished 316 or duplex LDX2101 bar. The duplex is much stronger and has similar corrosion resistance.
Plymouth Tube
