Assending order problem in tables
Hi
If you extract data to a table with 1-15 items say, and tell the items column to be in assending order it puts 10, 11, 12, 13 after the 1. eg the table column would read 1, 10, 11, 12, 13, 2, 3, 4, 5, 6, 7, 8, 9, Is this a glitch? I have blocks with an "item" attribute and would like the "item" column in numerical order. It works fine if you use 01, 02, 03 etc. Anybody come across this before. Using Autocad 2009.
RE: Assending order problem in tables
ht
ADT 2004
