Movement Joints in blockwork
Can you stagger movement joints in blockwork between floor to suit the building layout?
If so is a horizontal joint required at floor level?
RE: Movement Joints in blockwork
What do you mean by a horizontal joint at the floor level? A gap would only occur for non load-bearing walls.
Carl Bauer
www.bauerconsultbotswana.com
