1002 Steel vs 1026 steel in magnetics
Hello everyone,
as far as i know 1002 steel has a better performance in magnetics because it has less carbon than steel 1026, does somebody knows if there will ba a great difference using steel 1002 in a yoke used to atract an armature than using the 1026 steel.
The only think that matters in the yoke-armature design is the initial FORCE needed to atract the armature to the yoke, i do not care abaout the force ones is attracted .
Do you think 1002 steel will differ a lot from 1026 regarding the pulling force created by the yoke on the armature.
Thanks in advanced.
Thanks in advanced.
RE: 1002 Steel vs 1026 steel in magnetics
Mike
It's been mentioned in this forum numerous times, these grades of materials are not often processed to specific material properties.
