Can't select origin
Can't select origin
Can't select origin
With SolidWorks 2007, I suddenly cannot select the origin while working on a part.  Knowing SolidWorks as I do, I gather this is probably a configuration option that turned itself off for some reason.  Anyone know how I can turn it back on again?
RE: Can't select origin
Hmm, I figured out it's the selection filter.  But the toolbar is acting wonky and won't let me clear the filters.  Good old Solidworks, buggy as hell, it never disappoints.
I guess I'll just spend the rest of the afternoon clicking the toolbar until a combination of clicks clears the filters.
Nope, just deselected all filters, still can't select the origin.
Of course, I could select the origin two hours ago.
Can you see the origin?
What are your PC specs?
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
I can see the origin just fine, can't select it.
PC is having some RAM issues right now.  That may be the problem.
I've had this happen to me in certain odd situations (usually when I mess with complex curves and sweeps/lofts/fills).  In that case, I clear off what I need so I can see the Feature Tree, and select the origin from there.  Sometimes this doesn't register graphically, but is nonetheless selected.
RAM is cheap (unless you've got a Dell or laptop).  Might want to fix that little problem.
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
