How to scroll down the vertical toolbars
I am new user of SE and has started to work in draft environment. I have a small question.
Usually, the DRAWINGS and DRAWING VIEWS toolabrs are displayed on the left side of drawing window. Some of the toolbar buttons go out of range of my monitor view. If I scroll up/down the right scroll bar, only my drawing moves up/down.
If I move the toolbars at the top, the all buttons can be viewed. I am not sure how to access out of view toolbar button while the toolbars are displayed on the left.
RE: How to scroll down the vertical toolbars
If you recently installed solid edge, by default the apprentice mode is checked in the start window. This settings put automatically large buttons and enhanced text on. If you remove those settings then the toolbars will be a lot smaller.
I hope it helps
Patrick
I have verfied that in spite of "Large buttons" box is unchecked, the buttons on vertical toolbars run out of the display.
