Motor Run Capacitors
What are the consequences of replacing a 370 volt motor run capacitor with a 440 volt, same microfarad?
RE: Motor Run Capacitors
Zero.  Other than the cap will be physically a little bigger than usual and your wallet could suffer a bit more.  Otherwise it will even last longer.
Keith Cress
