Panelview plus 1000 usb drive path?
I am trying to save the log data onto the PV+ usb drive. The drive is recognized but I dont know how to define the path in the Datalog model in the factorytalk view studio.
Suggestion?
Suggestion?
RE: Panelview plus 1000 usb drive path?
If you have RSView software it suggests the addressing in the log file configuration.
Roy
Under Data Log / Datalog Models
C:\Logs
\\Server\Logs
\Storage Card2\Logs
There must be an equivalent for the USB
I have found the Versaview will only accept a limited No of cards, I think 64 Megs is about the maximum
Don't forget to turn on data logging under Startup.
Roy
