HEC-1 Graphical Interface Recommendation
It appears that I am going to need to use HEC-1 for a drainage study in a certain jurisdiction.  Does anyone have a suggestion for a good (and cheap) graphical Interface for it?  I'm to lazy to fight with the old dos program.
RE: HEC-1 Graphical Interface Recommendation
I have never seen one.  The USACE now uses HEC-HMS for hydrology instead of HEC-1.  You can import the files into HMS and it has its own graphical interface.  That is what I would recommend for free.
Normally I would use HEC-HMS, but I needed HEC-1 on this one. There are some functions in HEC-1 that aren't supported in HEC-HMS which the flood control district here uses.  They also have a lot of custom software built around HEC-1 that my model needs to work with.
I did find a Graphical Editor "Graphcial HEC1" from Bentley, but it doesn't work very well - wouldn't import certain cards.  I ended up buying RMSHEC2000 which is working out pretty well, but not quite as "Graphical" as I was hopping.
Thanks for your thoughts though.
Can you tell me what functions HEC-supports that HMS does not?  It was my understanding that HMS was an improvement in every way.
There's a list of them on page 52 of the HEC-HMS V3.0 Users Manual.  The ones that are making me go back to HEC-1 are the JD (Depth Area Storm) and UA (Specify Time Area Curve on a Clark or Snyder Unit Hydrograph) functions; these are called cards in HEC-1.
The flood control district I'm working with dictates the model and methods to use for certain drainage studies. So, I have no choice but to use HEC-1.
