custom exhaust w/o camshaft duration
I know I've seen afew questions on here in regards to making a custom exhaust, but what if you can't find the camshaft duration? I have a 1982 kz1000p that I would like to make a 4-2-1 system for... I thought this type of engine would be popular enough that someone would know something about it or could give me a jump start with some info they found about it. here is all the relavent information I can find for it;
Displacement 998 cc
Bore x Stroke 69.4 x 66.0 mm
Compression Ratio 9.2:1
Power 88HP@9000rpm 112Ft-lbs@8000rpm
and I ran one of those cfm calculators you can find online and got this for the intake;
CARB CFM vs RPM
140.98 @ 8,000 RPM
158.60 @ 9,000 RPM
I found a calculator online in regards to exhaust cfm and got these numbers;
(1200/540)*140.98 intake cfm= 313.28 exhaust cfm
the 1200 and the 540 were values they gave to get a multiplier for the intake cfm...
is there any help out there for this? or am I just shooting in the dark? Any info will be appreciated. thank you.
Displacement 998 cc
CARB CFM vs RPM
140.98 @ 8,000 RPM
158.60 @ 9,000 RPM
RE: custom exhaust w/o camshaft duration
There are several proprietary outfits making exhaust systems such as this. Have you checked them out?
Rod
evelrod, your primaries sound too short by quite a bit, but the diameters sound about right. If anything, the primaries should be a little smaller inside diameter than that.
Oh, by the way, I got the "13" dimension from Cosworth!
Rod
