Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your information in this site is absolutely WONDERFUL. It is the most useful site on the web to me right now. Thank You Thank You..."
Geography
Rhue (Industrial)
13 Aug 08 15:56
Here's the problem...
I need to extend and contract two cylinders.
Much like the spring loaded part that holds a toilet roll but I can't use a spring.
What I'm looking for is a thermal expander that when one end is heated (low heat) the unit will expand.  Once it cools the unit will contract.  And the whole unit is about the same size on the before mentioned toilet roll holder.
Does anyone have any ideas?  Or can you point me in the right direction?
Best regards,
Rhue
mcgyvr (Mechanical)
13 Aug 08 16:08
Wax (think of a car's coolant thermostat)
Bi-metallic strips
shape memory alloy
Need more info like amount of force required,etc..
What is meant by low heat?
hydtools (Mechanical)
13 Aug 08 18:08
Extend how far?
What temperature?
Ted
Rhue (Industrial)
13 Aug 08 19:41
The force required shouldn't be much (lifting less than 3 ounces).
It needs to extend about 4 inches.
Temperature is between 500 and 600 degrees celcius.
Any ideas will help.
Thanks again,
Rhue
danw2 (Industrial)
18 Aug 08 22:29
bellows?
desertfox (Mechanical)
19 Aug 08 7:37
Hi Rhue
How about length and diameters of cylinders and are you extending and contracting between 500 and 600 degrees C ?
hendersdc (Mechanical)
19 Aug 08 14:32
Gas Piston?  I have the same question as desertfox, is the temp cycling between room temp and 500-600 or only 500-600.  Air is about a third as dense at 500 C as at 20 C.
Close Box
Join Eng-Tips® Today!
Join Us             Close
