Air Conditioning
Air Conditioning
I may have to put together a air cooling system. One option is to blow air on a finned tube like an evaporator. My question is what if I do not have enough heat in the air to evaporate all the refrigerent? How is this done in standard a/c applications? Are there heaters or expansion tanks used to make sure that only gaseous refrigerent goes into the compressor?
RE: Air Conditioning
The suction pressure is often monitored, and the compressor will either unload, or shut-off when it drops to low.
Some systems will incorporate a suction accumulator to prevent liquid from reaching the compressor under unusual operating conditions.
Some systems will incorporate a suction/discharge heat exchanger.
