Thermosiphoning
Thermosiphoning
I have a situation where there is a reservoir of hot water on top of which is a vertical tube closed at the top end. The vertical tube is in communication with the hot fluid at the bottom and is air cooled externally. I am trying to determine the natural circulation flow rate inside the tube, internal fluid temperature profile, and the internal heat transfer coefficient.
I have found plenty of papers and information for thermosiphoning where the hot and cold fluid streams are physically separated but very little with respect to the flow situation I am trying to model. If anyone has experience in this area or could point me to some information, it would be greatly appreciated.
RE: Thermosiphoning
