Heat Sink Surface Finish & Flatness
I am looking for information regarding heat sink surface finish and flatness.  My particular problem is as follows:
I have a small extruded aluminium heat sink (approx. 25mm long, 20mm wide and 13mm fin height) with 15W dissipated from a small (10 by 12mm) heater.  The heater is screwed onto the rear face of the heat sink.  Heat sink thermal resistance is approx. 3.4 degC/W.
For thermal interface I am using Graftech eGraf 1210 (0.25mm thick, 10W/m-K through conductivity).  In tests with a machined sample heat sink with the mounting face sanded smooth this has given be performance as expected.
However I have no experience with extruted heat sinks so do not know what surface finish to expect.  I have read that the surface finish of extrusions is often good enough as supplied, without post machining.
I would like recommendations on surface flatness and finish for the above application and whether a post machining operation to smooth the surface would be required.
If a post machining operation is recommended then what surface flatness would be required.  The machined sample had a sanded (using P400 Wetordry) finish on the mounting face.
Thanks.
RE: Heat Sink Surface Finish & Flatness
In regard to the surface finish, I think the fact that you have a thermal interface material will minimize the requirements for surface finish.  I would think something like 16 microinches or 32 microinches would be sufficient.  Ask the supplier of the thermal interface material what they recommend; that'll give you a sanity check.
The flatness specified should be such that any bow in the heatsink is smaller than the thickness of the thermal interface material.
Thanks - that's pretty much what I thought.
Diecast heat sinks have higher infrared emmitance than the smoother extruded variety.  If you have considerable radiation heat transfer this is something to consider.  Also pin fins are usually a better choice over a ribbed heatsink (when they both occupy the same volume) when the pin fins have the right average diameter and spacing.
Tunalover
