Transfer settings from old to new computer
Hi Edgers
I'm about to welcome a new computer and I would like to regroup all the tips and tricks to have a smooth transfer from my old computer to the new one.
I'm aware about the reports file contained here C:\Program Files\Solid Edge V20\Template\Reports. That I should copy to keep the hole settings, bom settings, etc.
What else should I know about? With your feedback I could also write a FAQ about this or maybe put it in the Solid Edge Wiki http://wiki.jasonnewell.net/Home.ashx
Also I don't know if it's a good idea to use the "Files and Settings Transfer Wizard" In windows XP pro as described here http:// www.micros oft.com/wi ndowsxp/us ing/setup/ winxp/migr ate.mspx#2
Thanks for the input
Patrick
Patrick
RE: Transfer settings from old to new computer
located under ..\SolidEdge Vxx\Program
- Holes.txt, IsoHoles.txt
- Custom.xml (saved settings for the Hole command)
- Options.xml (in use by SEAdministrator)
- seacad.ini and other .ini files used for conversion
(so far modified)
possible candidates (so far modified)
- ...\SolidEdge Vxx\Custom
- ...\SolidEdge Vxx\Frames
- ...\SolidEdge Vxx\Templates
- ...\SolidEdge Vxx\Images
- ...\SolidEdge Vxx\SampleBlocks
dy
We have to manually copy across draftlist & draftcallout but that's about it. We also have to select a few settings like text on buttons, sketch relationship colors, indicate underconstrained sketches etc.
KENAT, probably the least qualified checker you'll ever meet...
Go to "Start > Run" type in "regedit".
Then go to the "??_CURRENT_USER" & expand, then go to "Software" & expand, "Unigraphic Solutions" & expand, "Solid Edge" & expand. Right click on "Version X" and pick "export", then name the file and save.
Keep this file, then after you install Solid edge on the new computer, find this file "x.reg" and double click it and that is it. Toolbars and settings are magically still there! I had to do this on my computer after they wiped my profile off. It works and it is a life saver.
Hope this helps anyone that uses custom toolbars!
Jamie
Is it possible?
Patrick
yes, they are stored anywhere below the registry key. But be on your
guard: the SE registry entry contains a lot of pathes, so when
the file structure/drive letter assignment is not the same
on the new PC strange things may happen.
dy
