Error in running with Subroutine
I am working in Abaqus, my problem had a error when running the Job with Subroutine. Abaqus got a messenger "Error in Job: Problem during compilation - df.exe not found in Path". Please, help me to solve this problem.
Thanks.
RE: Error in running with Subroutine
I copied the file "df.exe" from Fortran into default directory, but there is same error in submiting Job. I am working in Abaqus CAE.
Can you help me to solve the problem?
Thank you very much.
You should edit the PATH system variable to include the path to df.exe.
Thank Xerf very much. After editing PATH with directories of df.exe, I finished and had good result.
