Strange Fitting?
Strange Fitting?
I have a strange fitting here that I can't identify. It is not threaded! It has strange, concentric rings on it.
http://flickr.com/photos/10466474@N04/2702862588/
Thanks!
Thanks!
RE: Strange Fitting?
Just for example:
http://www.sealexcel.com/union-ball-joint.html
Ted
Mario Souza
Application & Product Engineering
WMF Solutions Brazil
http://www.wmfsolutions.com
Good luck,
Latexman
The one that was there a couple of days ago looked sort of like an engine cylinder, i.e., fins on a short tube.
Mike Halloran
Pembroke Pines, FL, USA
http://
Good luck,
Latexman
MikeHalloran, you are right, it appears some people may be commenting on a different fitting. There are a bunch of photos on the FLIKR site, and when I pulled it up, I had to scroll through the previous photos top find what Chemeng421 was talking about, i.e. with the several rings that, as you say, could be likened to cooling fins on an engine cylinder.
Chemeng421: It would have helped if you had only put up the photo(s) to which you were referring, also if you had an idea of the size (looks like it could be quite a large nozzle?) It may well be some kind of manwya fitting for sanitary (food grade) equipment. If there are any dairy workers or dairy farmers in the forum, some of them may recognize it.
