Mechanical Symbols/Drawings
Does anybody know of a good book or website that explains how to read a mechanical drawing. Such as symbols for seals or bearings, etc.
Almost an "understanding mechanical drwings for Dummies."?
RE: Mechanical Symbols/Drawings
Don
Kansas City
However, I'm not sure that would necessarily cover the examples you list.
KENAT, probably the least qualified checker you'll ever meet...
The book that I would recommend is called "Technical Drawing" by Giesecke. If you're looking for a primer, I wouldn't bother with the expense of the very newest edition. At the other end of the spectrum, I also wouldn't waste my time on the 1940 version, either. http://www.alibris.com has used editions starting at 4.99.
I would highly recommend this book. It's what I used when I was in college studying to be a draftsman before I changed over to engineering. The principles are universal.
-T
Engineering is not the science behind building. It is the science behind not building.
If you're looking for symbols for bearings and seals, I have only ever seen them represented in one of two different ways:
1) As an accurate representation of the actual part, even in extremely old drawings of old machinery.
2) In a cross-sectional view, the sectioned portion is sometimes shown as a box with an "X" in it.
Other than that, I haven't seen seals or bearings shown as anything besides the accurate cross-section of the part.
Also, check out http://www.skf.com -- SKF manufactures bearings as well as seals. Browsing through their product literature will give you a good idea of what the enormous number of bearings and seals look like and what these bearings and seals are called. SKF gives really good graphics of their products and how they're shown on drawings.
-T
Here's the Amazon link, but you can probably find it in a used college bookstore:
http:
