Stainless Steel Design
Need to design stainless steel tube columns. (as well as tube braces) Searching the internet, I haven't been able to find any structural design equations specifically for stainless. Do I just use the AISC manual's equations ???
Looking to use 4"x4"x.180" Grade AISI 304L/304
I was given test result properties from the manufacturer:
Yield Strength Rp.2 =281 N/mm^2 (41ksi) (this is the Fy. correct? I'd never seen it with the Rp.2)
1% Proof Strength Rp1.0 = 333 N/mm^2 (What is this used for?)
Tensile Strength 614 N/mm^2
Any information on the design of stainless steel would  be helpful.
Thanks!
RE: Stainless Steel Design
Doubt it, refer prequalifications of AS 4100.
Regars,
Lyle
For use of SS in structural applications you should take a look at the design manual written by Finnish Constructional Steelwork Association.  I picked up a copy from Outokumpu stainless at a conference.  You might be able to get one through Stala Tube.
It includes equations based on the Eurocode.  It would be a good reference.
Plymouth Tube
