Compress Code Case suppression
I'm using Compress for ASME Section VIII Div 1 calcs, and want to suppress the code case 2260 options because my company doesn't use it. I'm fairly sure that there should be an option somewhere that allows me to disable it, but I don't know where it is.
RE: Compress Code Case suppression
Code Case 2260 for determination of required thickness for heads is applied to heads on an individual basis.
To set the use of the Code Case, "check" the option on the head design dialog.
   "Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
  Tom Barsh
  Codeware Technical Support
  www.codeware.com
