model tree won't show up in nav windown
i'm beating my head against the wall on this.
i can not get my model tree to be within my nav window. the option is greyed out under my "Show" tab. the model tree always pops up detached.
i even added the config.pro option "enable_tree_indep" and set it to NO, to no avail.
any ideas?
thx
any ideas?
thx
RE: model tree won't show up in nav windown
The "Model Tree Settings" should have its Placement setting set to As part of the navigation tabs .
Finally, remember to make sure that your window settings are saved to your startup working directory (set at the bottom of the Customize Screen dialog box).
