Caltrans Permit Live Loads
Does anyone know the axle spacing between any one set of axles which produce the 48 kip loading? Or if not the spacing then what does the 2'-3" and 4'-6" signify on the top right side of the sheet in the Caltrans Bridge Design Specifications?
RE: Caltrans Permit Live Loads
As I mentioned above 4'6" appears to be the out to out width of the double tires.
