Tilted nozzle on head
Is is possible to design a nozzle on head offset by XXX" and 45 degrees to the vessel longitudinal axis ? This is
very common situation while designing a vertical reactor with dump or withdraw nozzles on the bottom head> Thanks in advance.
RE: Tilted nozzle on head
However, you can likely model the nozzle as a radial nozzle whose chord opening matches the largest chord opening of the actual nozzle.
Two issues will be involved: (1) providing reinforcing area for the head opening per UG-37, and (2) ASME rules for the nozzle neck itself.
Modeling the nozzle with largest chord opening of the actual nozzle will meet the requirements of issue # 1 above but will be conservative for issue # 2.
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
www.codeware.com
