Reset a Panelview 1000
I loaded a new program into a panelview1000 and now it does not communicate with the PLC or the PC.  I go to configure RS232 DF1 devices and do an auto config and it says "Failed to find the baud and parity Check all cables and switch settings!  When I plug this cable into the PLC it sees the PLC.  I think I need to reset the panel.  Does anyone know how to reset a AB panelview 1000 operator panel?
Mike
