Lofting Complex Shapes
Hey Guys,
I was wondering if anyone else is having the same issue.
When using the lofting command with path curve an error appears saying "exceeded stack limit".
What is the stack limit and how do you change it? I looked into the SETVAR command to look into the variables in CAD but there is nothing pertaning to Stack limit. I use AutoCAD 08.
Keith
RE: Lofting Complex Shapes
Keith,
I think your machine (hardware/software) is flagging. Which system are you riding?
Can you share the "shape" before lofting?
Lothar
ADT 2004
Exxit,
I run a pentium 4 3.40GHz processor with 1 GB of RAM.
The graphics card is a 128 MB ATI Radeon X600 SE.
I attached a screenshot of the area in question.
I'm trying to loft the two top 3d splines using the path curve between them.
It worked on another computer with the same specs.
I guess its an software issue and I should re-install...
