Sidewalk Repair
Sidewalk Repair
During a tunnel inspection, it was discovered that a portion of the approach sidewalk had a large depression (surrounded by cracks and spalls). The depression in the sidewalk retains water near the wall, and the client would like to come up with a solution that drains the water back towards the roadway. The obvious solution would be to re-grade the sidewalk, but our client would like a simpler and less expensive solution. Has anyone encountered a similar problem in the past? If so, what solution did you come up with?
RE: Sidewalk Repair
