Background drawing to custom propert
Hi , I need to know how I write name template backround or sheet format automatically to custom property. How I do it ?
RE: Background drawing to custom propert
Please explain what you mean by Template Background & Sheet Format.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
neither the name of the used template nor the sheet's size
(i.e 'A2' or 'D') are available without doing some programming
hereby assuming your posting refers to a draft. The only thing
you can do is to add the location or the name of the template
manually to a custom variable within your template(s).
Same applies to the sheet size: add it as a textbox to each
background sheet .
dy
Thank you very much.
