Sweep - pipe with mitre corners
I'm trying to model a simple pipe (ie circular profile) with mitres corners.
The centre curve is not continuous in tangency, nor planar.
For a profile other than a circle, I understand that a reference surf or a pulling direction is required.
But for circular profile, there is a simple solution: a mitre plane at every corner. Lot of other softs can do that.
Anyone has an idea?
