Wood house shear wall
Please see attached sketch. Left side I can handle. How to check right side shear wall?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Wood house shear wall
can you draw collector element for me
If you need both shear walls to resist a large load, then I would design the corner as a re-entrant corner (that is, make a drag strut both directions at the corner, using blocking if you have to) and apply the shear load as if there was one wall line (i.e. proportional to the shear wall lengths).
