FEMAP API Programming
Does someone know the API program structure that would accomplish the same function within the FEMAP environment with renumbering solids?  The issue I'm having is how to re-associate the surface IDs with the renumbered ID for the solid when using feRenumber in an API.  Thanks in advance,
