Clean Steam Generator
I am looking for a clean steam generator that uses dirty steam to heat DI water into "clean steam". It would need to produce 125lb/hr of clean steam at 35 psi. The dirty steam is available at a minimum of 200lb/hr and 50 psi. Anyone have suggestions of where to buy one? I have already checked into Sussman. Thanks for the help!
-Steris
-Steris
RE: Clean Steam Generator
http://www.graham-mfg.com/sgoverview.html
-Steris
Can your requirement use steam from a steam purifier?
Check with Muellerand Steris
I have been using Finn Aqua model and I prefer them over demister pad type single column generators (for reasons unknown
You can get cheaper clean steam generators from Pharmalab, India. They are of fit and forget quality.
