Bottom weld
Bottom weld
Does anyone could tell me. Why is it recommeded, for API 650 Vertical tank, to make a buttweld joint for the bottom's plates with thickness of 3/8" and thicker?
Is There any trouble in having lap weld bottom joints?. Why?
RE: Bottom weld
Joe Tank
RE: Bottom weld
Could you clarify if is it possible or not to build a 3/8" plates lapweld bottom.
RE: Bottom weld
RE: Bottom weld
