Elastic Center
Elastic Center
I working on a design for an electronics box-type assembly that weighs about 50 lbs. We have vibration isolators mounted at each of the 4 corners. The vibration isolators work well in the vertical direction, but they appear to stiff in the two horizontal directions.
I was told by the vibration-isolator manufacturer that the lack of isolation in the two horizontal directions is due to the fact that the center of gravity of the box does not coincide with the system's elastic center. The system is comprised of the very-rigifd 50 lb box (10" X 12" X 15) and the 4 isolators.
I've modeled the vibration isolator in Cosmos and have found that the spring rates in all three directions are about the same.
Any help if pointing me in the right direction to understand how the elastic center comes into play would be greatly appreciated.
Dave Maxham
Dave Maxham
RE: Elastic Center
Chris
"In this house, we obey the laws of thermodynamics." Homer Simpson
RE: Elastic Center
Obviously, I'm still grasping at straws. I'll be hitting the books this weekend. I have Steinberg's vibration book for electronics - I hope something's in there about elastic centers.
Dave
RE: Elastic Center
The isolators generally are flexible in the vertical direction. This can translate to horizontal motion in the form of rocking.
How stiff is the horizontal motion compared to the original vertical spring stiffness is a matter of geometry.
If I mount a very tall box and push near the top of it, I don't have to push hard at all to distort the springs because I have a large moment arm due to the height of the box. Therefore, the effective horizontal stiffness at that height is very low.
RE: Elastic Center
RE: Elastic Center
Our arrangement is such that the isolators cannot rock because each one of the isolators' posts is mounted up against the flat surface of the unit.
RE: Elastic Center
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: Elastic Center
I think the old Lord catalog suggested the benefit of mounts at the same height as the CG is to keep the translational modes dominant, which are easier to calculate from mount stiffness.
My Volvo 240 has very squishy mounts close to the engine and rocks like a mother at idle, but keeps the whopping secondary vibration from the 2.3 liter 4 fairly well isolated.
Our Volvo 740 using ~the same red block 4 cylinder had similar looking mounts on outriggers attached to the block, but was a much more refined car.
RE: Elastic Center
Look's like everything is pointing to having the mounts higher up to be in line with the center of gravity. I've also gone up the learning curve in regard to rocking modes, etc.
RE: Elastic Center
We have an in-house vibration table that has a vertical motion only. Whenever we have to do lateral tests, we go to an outside testing facility that has a horizontal-motion table.
I have this idea (good or bad) that we could use our vertical-motion table for at least some of our horizontal tests. This would be done by first mounting a large enough right angle structure (like a big L) onto the vertical-motion table. Then we would mount the unit under test to the vertical section of the big L. Then when the table went up and down, the unit would be subjected to a vibration in one of it's employed, horizontal axes. Then the other horizontal axis could be tested by rotating the unit 90 degrees.
I don't know if my idea makes any sense. I worked at a place a number of years ago where we did such a thing, but the units or objects under test were much smaller. In our case, the unit under test weighs about 50 lbs. I understand that the isolators described above will be initially compressed in their employed, radial direction, but to me that seems the same thing as when the unit is mounted directly on the vertical-motion table without any angle structure, just in a different axis.
Any help and pointing in the right direction is greatly appreciated.
RE: Elastic Center
Cheers
Greg Locock
RE: Elastic Center
