12V DC power supply in the same conduit with CCTV wires
Would there be any effect (interference) if the 12V dc power supply cable is inside the same conduit together with the CCTV cable even if the voltage is very low?
Arvin
Arvin
RE: 12V DC power supply in the same conduit with CCTV wires
The power line will be the supply for the CCTV cameras itself. Instead of having a separate conduit, they plan to combine in it one conduit.
Keith Cress
