Force Main/pump Staion
I am trying to understand a sewage pump and force main design.
The total pipe required for the design is about 5600 ft .
The high point of the design 676 ft is at 1200ft from the lift station.(the elevation at the pump station is 658ft)
Then the elevation constantly decreases and at the discharge manhole the elevation becomes 645 ft. (exacavation is an issue and forcemain is a must)
My question here is for my head loss due to friction calculation, do I have to use 5600ft or 1200ft. my assumption after the high point the flow will run by gravity even though it will be just the same force main .
Could you please give me a good website that has a good example sewage pump station design .
Thanks for your help
RE: Force Main/pump Staion
Remember to model various flow conditions and to plan for the entire drainage area, not just this particular development.
The cost difference would vary depending on the size of the force main, size of the sewer, number of road crossings, depth of excavation, and subsurface conditions.
Go buy the book:
Collection and Pumping of Wastewater
by Metcalf & Eddy.
