Is there a fill rate limitation for DOT cylinders?
Hello, is there a reccomended or maximum limit for the flow rate when filling or venting TC / DOT cylinders with air? I am preparing maintenance procedures that will require filling and venting 43L cylinders. I have made inquiries with DOT and TC but have not got a reply. My compressor is limited to filling one bottle every 26 minutes. I am not sure how fast venting can occur. We have a couple of shutoff valves and a muffler on the exhaust line.
TIA
TIA
RE: Is there a fill rate limitation for DOT cylinders?
ht
"If everything seems under control, you're just not moving fast enough."
- Mario Andretti- When asked about transient hydraulics
http://virtualpipeline.spaces.msn.com
