Strange structure
Strange structure
Recently I was inspecting a building and noticed that fixed baseplate connections were used even when having braced frames! I also noticed moment beam to column connections where we have braced frames! Has anyone ever seen anything like this before? What the heck.
RE: Strange structure
Fixed baseplate connection - rarely completely fixed as in assumption.
Moment frame - sway is usually small, but not completely out of the picture. Talk to the guys there, you may find reasons for using the braced moment frame.
Of course it could be modeling error or a misreading of 13.3b of AISC 341-05.
I have no idea about the beam/column connections. Well, I have one, but it seems kind of crazy.
I agree.... I had a project where we had a few wind only columns that were only welded on the web. They left them unbraced for the weekend during building erection (before the beams at the top were attached) and a high wind ripped the the column about 2'-0" from the base. That was when I worked for an A/E firm. Of course, erection is supposed to be the contractor's responsibility, but you will ALWAYS get the call about how to salvage the column that has been damaged.
Now I work for a D/B firm and you bet if something like that happened it would be my problem. We always weld all the way around. Many contractor's do not brace 1 story columns during erection (even if they should). Only welding 1/2 the web to the base plate would certainly lead to many of our columns failing during erection. ASIC has a document on erection bracing of columns and covers wind load and weld capacity during erection.
For an 8" column, the smallest column, this creates 675 lbs of tension on one face. Using ASD, the capacity of 1 inch of weld 927 lbs per 16th inch of effective throat.
In other words, I only need one inch of 1/16" fillet weld to support this OSHA load. Doesn't seem like a problem to me.
That is only in the major axis, what about arounf the minor axis. I think you will find that harder to justify.
I have two lines of weld on a W8x24 column, which has a 6.5 inch flange. If I use a 1/16" weld 4 inches long at each flange and consider the load as actually horizontal to the ground at 18 inches above the base plate (a conservative approach considering the load is a vertical one not a horizontal one):
AISC 13th Ed: Table 8-4 page 8-66:
e_x = 18 inches
l = 6 inches
a = 18 inches / 6 inches = 3
C_1 = 1.0 (E70xx electrodes are common practice)
D = 1 for 1/16" weld, much smaller than my actual weld
k = 0 when the load is not in plane with the welds
Omega = 2.0 for ASD
From the table, C = 0.439,
Using the equation:
l = Omega * P / (C x C_1 x D)
And solving for P,
P = l x C x C_1 x D / Omega
P = 6 x 0.439 x 1.0 x 1 / 2 = 1,317 lbs.
This doesn't include welding on the web which also adds some capacity to the weld group. I also have to use the minimum effective throat depending on the thickness of my baseplate. Again, I think I am just fine. Does anyone else see an issue that I don't?
