True View Generation
I am attempting to create a true view of a brake pad's
end chamfer. What Icon would I use to accomplish this?
RE: True View Generation
true view ?  Define true view pls.
Eric N.
itsmyjob,
that would be a view along a certain vector.
thanks
Here is an update to my question on true view generation
using Catia V5. Attached is a simplified part for discussion. I will need a view in the direction of the
arrow.
Thanks again
Another way: make a plane perpendicular to the line of sight (chances are you already have a face or plane you can use), and then make a Front View.
thanks all for input
