drawing layer sheet specific
Are drawing layers not sheet specific?
I'm creating 3 drawing sheets 1 weld assembly and 2 lasered parts all within the same SW drawing.  Our laser software like most requires a specific laser layer and other info on another layer.
In my weld assembly sheet I dont need those layers on so I turned them off.  That turned them off on my laser drawing sheets.
Not a huge deal having 3 SW drawings but that just creates 2 more files that aren't really needed.  I suppose I could create more layers also.
Grant
Applications Engineer
SW2008 X64 SP 3.1
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
RE: drawing layer sheet specific
No, they are not sheet specific. you will need to create all of the layers needed, then assign your info individually on each sheet. A little different than ACAD.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
