Re-rating vessels
Re-rating vessels
I have a double-pipe reactor (20" ID) that I would like to re-rate for a different temperature and pressure (probably to 75 psi and 482 deg F, currently it is 145 psi and 392 deg F). Is this considered a pressure vessel or can I classify it as a speciality item? If it's a pressure vessel then it i smy understanding that I have to take a bunch of UT measurements and then pay a shop to do the calculations and give me a stamp. But if I classify this as a specialty item, then is this still the case?
thanks,
chris
thanks,
chris
RE: Re-rating vessels
Anything at or above 15 psi is considered a pressure vessel.
Specify what you mean with the term specialty item.
The only people with the remote possibility of certifying the reactor is the original manufacturer as he is the only one who can stand by his previous quality and workmanship. It is impossible for anyone to certify an existing reactor built by others due to obvious reasons, and the lack of detailed information such as but not limited to i.e. welding parameters, material specifications, and extent of the Authorized inspector involvement or lack thereof.
My best suggestion for you is to approach an ASME certified shop that is a holder of the R Code stamp, and ask for his input. Tell him also about the relief valve parameters.
I am sorry I couldn’t be of much help.
Re izamil's post, existing vessels can not be certified & stamped as ASME. ASME is an in process Code, & does not allow for post construction certification. cdgilbert would need to contact the Jurisdiction to determine the conditions under which the vessel may be used.
I don't really know about the R stamp but from what I have heard this is your best bet. Without the original construction records, and all associated documents, there is no way you can get a new code stamp for the vessel.
I suggest you check out RC-3022 in the NBIC book. It doesn't say that you can't perform the re rating but it does require sufficient tests to prove its ability to perform at this new rating. Hope this helps
