Naphthenic Acid corrosion in Duplex SS
hI,
for a pump operating wiht naphthenic acid content > 2% (atmospheric residue pump) and 339ºC, the proposed material for shaft is Duplex SS (UNS 32205). I know the resistante for such organic acids depends on the alloy content. For high naphthenic acid content-high turbulence and high temperature, % Mo is the element which determine the resistance (Tp 317L is ussually used). Is it correct?
Is Duplex acceptable provided that this material has Mo:3% min? Any experience with this material in this service?
Peter
Peter
RE: Naphthenic Acid corrosion in Duplex SS
As the (UNS 32205) has 3.2% of Mo against 2.2% of 317L in principle it will resist more to NAC corrosion than the 317L.
luis marques
The Mo contents point of view, DSS may be an alternative metal to 317 SS in NAC with ClSCC environment, 600F and below. However the DSS may have to be carefully selected because the industrial data (either problem or no-problem) for NAC of DSS are not enough.
