Export .dft to dwg using options - computer crashes
I'm using solid edge V19 and trying to export dft. to dwg
When using the options button the system crashes.
It does the same thing with the free2d version of the program..
I need to use the options button to tell the program to use mm instead of inch otherwise my 1mm will be converted to 1 inch..
Thaks for you help
Anders
RE: Export .dft to dwg using options - computer crashes
on export there is no option to set the units only on
import. But to overcome you may modify your seacad.ini
to use mm for import:
Read Default Units=61            (64 will be Inch)
the line should be near the top of the file
dy
Hello donyoung thanks alot!
It worked, now i dont have to push the options buttom!
that saved me for now
Have anyone an idé how i can come around the problem with haveing the options buttom locking the system?
Regards Anders
