Macro to Reverse Order
I want to reverse the order of each section and tried this.  What did I do wrong?
'  Reorder each section
    Range("B4").Select
    npts = ActiveCell.Value
    Do Until npts < 1
        ActiveCell.Offset(1, -1).Activate
        sRow = ActiveCell.Row
        For n = 1 To npts
            x(n) = ActiveCell.Value
            ActiveCell.Offset(0, 1).Activate
            y(n) = ActiveCell.Value
            z(n) = ActiveCell.Value
        Next n
        Cells(sRow, 1).Select
        For n = npts To 1 Step -1
        Next n
        ActiveCell.Offset(4, 1).Activate
    Loop
I get an error on the first x(n) line for end of statement.  Will the check for npts<1 be met when I run out of data at the bottom?
Roger
RE: Macro to Reverse Order
Any lines I added are all the way Left Justified. Anything of your's I wanted to change, I commented out and then copied/changed on the next line.
I suggest you use cells(sRow, sCol).select (or .value, etc...) in the future. It can be easier to manage than the Offset command (at least that's my preference).
Enjoy,
Ken
CODE
Dim x() As String
Dim y() As String
Dim z() As String
    Range("B4").Select
    Do Until npts < 1
sCol = ActiveCell.Column
ReDim x(npts)
ReDim y(npts)
ReDim z(npts)
        For n = 1 To npts
Cells(((sRow - 1) + n), sCol).Select
        Next n
n_2 = 1
Cells(((sRow - 1) + n_2), sCol).Select
            'x(n) = ActiveCell.Value
ActiveCell.Value = x(n)
            'y(n) = ActiveCell.Value
ActiveCell.Value = y(n)
            'z(n) = ActiveCell.Value
ActiveCell.Value = z(n)
n_2 = n_2 + 1
        Next n
    Loop
End Sub
I haven't studied the code and not sure exactly what you're trying to accomplish.
IF you want to reverse the order of some rows of data - that's a snap.  Add an extra column for an index number in ascending order.  Then sort on that column in descending order.
Sorry if I misunderstood the question.
I just had "Dim x()" y & z at the top.  Will my numbers be affected by Dim As String?  And I did have the equations turned around backwards.  I'd have caught that one the first time I got that far.  Thanks for the help.
And you understood the ?.  I guess I could write the macro to add an extra index column to sort on.  Thanks pete.
Here's another approach you may find interesting.
CODE
Sub test()
  Dim b As Range
  a = Selection
  Set b = Selection.Cells(1, 1)
  n = UBound(a)
  For irow = 0 To n - 1
    b.Offset(irow, 0).Formula = a(n - irow, 1)
  Next
End Sub
cummings, I'll need help understanding this one and how to apply it to the data.  Here's an example.
Header
Header
Header
NPTS 13    13
-0.042282194    1.500317076    -0.064645944
-0.022277818    1.500350089    -0.086256151
-0.002509365    1.500382076    -0.107855452
Header
Header
Header
NPTS 25    25
and so on
Ken,  I had to move the ReDim inside the Do loop because npts is something new for each set of data.
Here's what worked:
    Dim x()
    Dim y()
    Dim z()
    Range("B4").Select
    Do Until npts < 1
        ReDim x(npts)
        ReDim y(npts)
        ReDim z(npts)
        For n = 1 To npts
            ActiveCell.Offset(1, -2).Activate
        Next n
        Next n
        ActiveCell.Offset(3, 1).Activate
    Loop
I don't need the sRow line.  Thanks a bunch.  I'd never have figured out the ReDim.
Roger,
I've also seen people just initialize the array at some overly large value, like:
Dim x(1000)
Dim y(1000)
Dim z(1000)
They figure there's no way they'll ever need 1000 rows of data, and they don't want to mess with ReDim (or maybe don;t know how or that they will even need to resize it).
Also/Or, if you want to resize an array but not loose you're existing values, look up ReDim Preserve.
And since we're on the subject, to find the size of an array you would do somthing like:
Debug.Print Ubound(x())
Probably more information than you were looking for, but these are some tricks I've learned when using arrays.
Later,
Ken
Why doesn't this work?
Dim x()
Isn't that supposed to do it dynamically?
Roger, I've made some minor changes to the rest code as follws:
CODE
Sub test()
  Dim b As Range
  a = Selection
  n = UBound(a)
    b.Offset(irow, 1).Formula = a(n - irow, 2)
    b.Offset(irow, 2).Formula = a(n - irow, 3)
  Next
End Sub
The way it works...
First select the data range you want reversed.  In your sample data it would be
run the code and you get
HTH and is what you are looking for
Yup, that'll work.  A small modification will allow it to work regardless of number of rows in the selected range:
CODE
Sub test()
  Dim b As Range
  a = Selection
  n = UBound(a)
    For icol = 0 To Selection.Columns.Count - 1
     b.Offset(irow, icol).Formula = a(n - irow, 1)
    Next icol
  Next
End Sub
Correction:
"...regardless of number of columns in the selected range:"
Whoops. Looks like that didn't work. Never mind.
My modification to cummings code created some new problems.
There was a "problem" (depending how  you look at it.  cummings code will convert formula's to values.  The variant a array apparently stores the values rather than the formulas.
electricpete,
If formulas you want, formulas you get big smile
Just change the array assignment as follows:
CODE
a = Selection.Formula
That does not give the intended result.  Relative formula's are not updated properly when you plug them in.
For example, put the following formulas starting in A1
1    =+A1*2    =+A1*3
2    =+A2*2    =+A2*3
3    =+A3*2    =+A3*3
Which of course displays as follows:
1    2    3
2    4    6
3    6    9
Run the macro with the change you mentioned and the resulting formulas are:
3    =+A3*2    =+A3*3
2    =+A2*2    =+A2*3
1    =+A1*2    =+A1*3
Which displays as:
3    2    3
2    4    6
1    6    9
I'm sure there is a way to fix it, but it won't work as it is.
Here is the sorting approach:
CODE
Sub reverser()
 Dim target As Range   ' holds the original range
 Dim myRow As Range ' Holds the current row of target during for loop
 Set target = Selection  ' Initialize target
 ' select first col of range in prep for adding sort column:
 target.Columns(1).EntireColumn.Select
' add column to the left of original selection:
 Selection.Insert Shift:=xlToRight
 ' Populate column to left of original range with a sorting index (row)
 For Each myRow In target.Rows
   myRow.Offset(0, -1).Resize(1, 1) = myRow.Row
 Next myRow
 ' Select the expanded range (including index column) in preparation for sorting:
 target.Offset(0, -1).Resize(target.Rows.Count, target.Columns.Count + 1).Select
 ' Sort:
 Selection.Sort Key1:=Selection.Cells(1, 1), Order1:=xlDescending, _
          Header:=xlNo, OrderCustom:=1, MatchCase:=False, _
          Orientation:=xlTopToBottom
 Selection.Cells(1, 1).EntireColumn.Delete ' Gets rid of the index column
 ' reset the selection to its original size (one column less than expanded selection):
 Selection.Offset(0, 0).Resize(Selection.Rows.Count, Selection.Columns.Count - 1).Select
End Sub
Roger,
Dim x()
Arrays can be re-sized during macro execution (i.e. dynamic) by using the ReDim. So yes it is dynamic, but it does not automatically resize itself.
Ken
I forgot to mention one thing, for my macro you need to highlight a range of interest (any size, any location) and then run the macro to reverse the rows within that selection.
Now that I know how to reverse the section order, how do I ensure that the points go around the body in order?  This will end up in some grid generator and I don't want it to wrap back around itself.  I can't sort on x,y,or z because one or the other goes from negative to positive and back. These are 3D points around the leading edge of a very thin airfoil.  There must be some math that can determine this.  The offending points can just be deleted; I have way more than I need anyway.
The y plane has the least variation as the cuts were made that way.  Nevertheless, the points are of sufficient density that I basically have a cloud of points along a small band (y plane) around the airfoil.
