Scaling Imported IGES files....
I am trying to import an IGES file into SW 2008. I can import it as either importedcurves or a 3d sketch. (its the centerline of a complex curve, similar to a helix)
The problem is that the imported curve is 25.4 times bigger than I need.
The sketch tool scale is not available....
how do I scale the curve to get it from reading in as inches, its actually metric.
(I can't change the way the iges file is made, its just given to me.)
nick
nick
RE: Scaling Imported IGES files....
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
IGES file is in mm, object (curve really) is ~309mm end to end.
When imported using template setting under options menu, and the template is in mm, the evaluated Z height is measured at 7586.22mm.
When imported using the option to use file units the object ends up as ~309in end to end.
If I could just 3d scale the object by 1/25.4 I could get the size I need, just dont have any clue how to do this.
nick
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
nick
What an odd problem. Have you contacted your VAR about this--they ought to have encountered this problem before.
Jeff Mowry
Here's a possible workaround:
1) Generate a swept surface using the imported curve as your path. The profile should be such that the resulting surface creates edges that coincide with your imported curve.
2) Scale the swept surface appropriately.
3) Create a 3D sketch, extracting the edges of interest.
I believe this will yield what you're looking for, albeit with a few extra steps.
Jeff Mowry
Jeff Mowry
NickE, did it work?
Jeff Mowry
nick
IGES file header per DRAFT v6 1998-01-05 18.
Global Section (reference 2.2 pg 18 Table 1)
1) String Parameter delimiter character.
2) String Record delimiter character.
3) String Product identification from sending system
4) String File name
5) String Native System ID
6) String Preprocessor version
7) Integer Number of binary bits
for integer representation
8) Integer Maximum power of ten representable
in a single-precision floating point number
on the sending system
9) Integer Number of significant digits in a
single-precision floating point number on
the sending system
10) Integer Maximum power of ten representable
in a double-precision floating point
number on the sending system
11) Integer Number of significant digits in a
double-precision floating point number on
the sending system
12) String Product identification for the
receiving system
13) Real Model space scale
14) Integer Units flag (see pg 20; 1 = in, 2 = mm, etc.)
15) String Units Name ***** (Redundant unless [14] = 3) *****
16) Integer Maximum number of line weight
gradations. Refer to the Directory Entry
Parameter 12.
17) Real Width of maximum line weight in units.
Refer to the Directory Entry Parameter 12
(see Section 2.2.4.4.12) for use of this parameter.
18) String Date and time of exchange file generation
15HYYYYMMDD.HHNNSS or 13HYYMMDD.HHNNSS
where:
YYYY or YY is 4 or 2 digit year HH is hour (00-23)
MM is month (01-12) NN is minute (00-59)
DD is day (01-31) SS is second (00-59)
19) Real Minimum user-intended resolution or ******************
granularity of the model in units specified ***************
by Parameter 14. ******************************************
20) Real Approximate maximum coordinate value
occurring in the model in units specified
by Parameter 14.
21) String Name of author
22) String Author's organization
23) Integer Flag value corresponding to the version
of the Specification to which this file complies.
24) Integer Flag value corresponding to the drafting
standard to which this file complies, if any.
25) String Date and time the model was created or
last modified, in same format as field 18.
26) String Descriptor indicating application protocol,
application subset, Mil-specification, or
user-defined protocol or subset, if any.
I'm assuming you have a standard Fixed Format ASCII file.
You can change the units using a text editor.
Use fixed width font, i.e. Courier.
This message should be viewed using same.
Global section fields are variable length (usually comma) delimited.
All lines are 80 characters.
Strings are prefixed with character counts, i.e. 63H, 22H in fields
[3] and [4] below.
The above was taken from (never to be implemented?) IGES 6.
The headers in IGES 5.x are the same.
Units are defined by field [14] or [15].
Sample inch:
,,63HD:\MyData\Reference\Aircraft\Boeing\Boeing_3_Views\737-700w.dwg, G 1
22HD:\MyData\737-700w.igs,53HAutoCAD-16.0 (Microsoft Windows NT Version G 2
5.0 (x86)),87HAutodesk IGES Translator Mechanical Desktop.R7.0.43.0 (MarG 3
18 2003) from Autodesk, Inc.,32,38,6,99,15,63HD:\MyData\Reference\AircrG 4
aft\Boeing\Boeing_3_Views\737-700w.dwg,1.0D0,1,2HIN,211, G 5
8.30708661417323D-2,15H20040414.223429,2.90688854527066D-6, G 6
2906.88854527066D0,,,11,0,15H20020213.110902,; G 7
Line 5 extracted:
indicates it's an IN(ch) file.
("1.0D0,1,2HIN,211," are fields [13] thru [16])
Line 5 modified so it will be interpreted as mm:
aft\Boeing\Boeing_3_Views\737-700w.dwg,1.0D0,2,2HMM,211, G 5
If your file has something like "4HINCH" in field [15],
change it to "2HMM" and <SPACE> the "G" back to #73.
HTH
-Jeff Howard (wf2)
Sure it's true. I saw it on the internet.
Nick
I love materials science!
Field 14 is an integer field and should be 2 for mm.
Field 15 is redundant unless [14] = 3, which tells postprocessor to use field 15.
Field 15 is a string field and should read (for inch or mm)
2HIN
4HINCH
2HMM
I see what you were trying to do with the 'scale factor'. It's just not supposed to work that way.
Out of curiosity would you post the appropriate line from your original file and your modified file? Or zip and post the .igs.
-Jeff Howard (wf2)
CODE
1H,,1H;,,10Hcase0.iges, G 1
5HANSYS,21H 8.1 UP20040329,,,,,,,1.0,,,,,13H000725.071414, G 2
1.0000E-04,,,,9,,; G 3
in line G2 (the actual third line) the 1.0 when replaced with 0.03937HMM worked for me.....
nick
I hate to leave things dangling without understanding,
at least in part, and I learned something from this.
What you actually changed was Field 13, Model Space Scale.
Fields 14, 15 are empty (defaulted to inch). I guess the
postprocessor read the "0.03937" scale factor,ignored the
invalid "HMM" portion and went on about it's business
reading in a scaled inch model.
What line G(lobal section) 2 should look like for a millimeter
file, if you're curious:
5HANSYS,21H 8.1 UP20040329,,,,,,,1.0,2,2HMM,,,13H000725.071414, G 2
The attachment is a breakdown of the line and some extracts from
the IGES spec.
IGES specifications can be found at ...
http://www.iges5x.org/archives/version5x/
... if there's an interest.
Have a good'n.
-Jeff Howard (wf2)
