NAS Parts Library
NAS Parts Library
Does anyone here use an NAS library on a daily basis? I dont have one and I keep having to insert toolbox parts and assign properties which is a huge pain. Also, the toolbox parts are exactly like the NAS parts so there's room for mistakes.
Thanks in advance.
Thanks in advance.
SW2008 Office Pro SP3.1
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot/SpaceNavigator
RE: NAS Parts Library
Go to this website:
http://www.3dcontentcentral.com/default.aspx
Then go to the user library, and then search for "NAS". I have uploaded files for this specfic use. Other users did the same. I do not use the out-of-the-box SW toolbox hardware because of it's crappy naming conventions and descriptions.
Hope this helps,
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
I'm just a little verklempt. Talk amongst yourselves. I'll give you a topic. Pink Floyd, was neither Pink nor Floyd. Discuss!--"Coffee Talk" Mike Myers SNL
2.2GHz, 2.00GB RAM
QuadroFX 3700
Mechanical Designer
Go to the site, http://www.mcmaster.com/
Type in the search box "NAS". Not all have CAD files, but a lot do.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
anyone?
2.2GHz, 2.00GB RAM
QuadroFX 3700
Mechanical Designer
Mechanical Designer
2.2GHz, 2.00GB RAM
QuadroFX 3700
Mechanical Designer
http://www.usmilitaryfasteners.com/part-search.htm
Chris
AutoCAD 06/08
I combined the PDF's (in the order listed) from the site Chris reference into one file. It's a lot easier to browse.
Mechanical Designer
Mechanical Designer
Mechanical Designer
2.2GHz, 2.00GB RAM
QuadroFX 3700
hopefully with every configuration possible with assigned dash numbers and full properties. Wishful thinking I Know!
2.2GHz, 2.00GB RAM
QuadroFX 3700
It sounds like you need to start drawing these unique parts by yourself. Maybe someone out there can help you on your quest.
Best,
Mechanical Designer
2.2GHz, 2.00GB RAM
QuadroFX 3700
Mechanical Designer
