Air line pressure drop
I am not a process engineer, and I have right now a quite basic problem I need to solve, therefore your help would be appreciated
I have to calculate the pressure drop of a air tubing, that goes from a reservoir to a horn.
Line is 1/2" SStubing 0.035"
Length: 50 ft straight+ 5 x 90º bends
Air is at 100 psig, 104ºF
Airflowrate: 21cfm@150psig
Could you tell me how can I calculate the pressure drop?
Basic lesson!!
Thanks in advance
RE: Air line pressure drop
26.2 bar
above result is for smooth pipe
Thanks Kraasek!
Buyt if you notice..pressure drop is higher than pressure available
