PVC Polyblend?
PVC Polyblend?
PVC Polyblend?
CD's are placed on a PVC Polyblend pad and are then printed with UV curable inks.  These inks tend to stain the plastic pad and I have not found a reliable way to clean the surface without ruining it.  Does anyone have a suggestion on what type of material to use?  The pad has been designed to resist chemicals so that is an option.  But what should be used with the chemical?
